Terryallan
Jun 19, 2015Explorer II
Campfire Time wrote:Terryallan wrote:
However. the yellow sticker weight is the actual weight of the TT as it sits in front of you on the dealer lot. As it was built, with everything you see on it.
The OP asked about dry weight. Dry weight is an empty trailer without options. That is always a lower weight than the "As Shipped" weight on the yellow sticker.
I agree that few people tow their trailer at it's GVWR, but that's a more realistic number than the yellow sticker. But here's the reason the yellow sticker is almost as bad to go by as the fictional dry weight, the only time you will tow the weight of the yellow sticker is the day you drive it off the lot. After that you will be a minimum of 500# over that, and most people are probably going to add 1000# to it.
In most instances what people put in their trailers is going to put them closer to GVWR than Shipped Weight. If you use the GVWR, then you will ALWAYS be right. If you use the "As Shipped" weight, you may be closer to your capacities than you think. In the OPs case, if they get a trailer with a 4500# yellow sticker and add 800# of stuff, now they are at 5300#. Sounds OK, except for the fact that they have an SUV that may only have an 1100# payload. If the tongue is 13% or more, more than half their payload is gone. If they stick with a 4500# GVWR trailer, they'll still have a fighting chance at not using up their payload, and they'll enjoy towing far more.
I can tell you from personal experience, the more margin you leave between your towing capacities and the true weight of your trailer, the more pleasant the towing experience.
The yellow sticker is a place to start. To give you an idea of how much it will weigh once you put your stuff in it. The GVWR is more of a irevelant number. Think about it. Yellow sticker 4500 lb. GVWR 8000lb. Which do you think is more realistic? Why would I need to worry about the 8k GVWR when the trailer weighs less than 6000?
Answer. I don't.
Example. My TT was 4811lb from the factory. The GVWR is 7200lb. My TT weighs 5650lb ready to camp. Going by the irelevant GVWR I couldn't tow my TT. If I used the TT GVWR to size my TV. Loading the kids, firewood and bikes would put me over payload. But since I am 1550lb UNDER GVWR. I have no problem. So I use the more helpful yellow sticker to get me in the ballpark. Because I KNOW I will NEVER load the TT to the GVWR.
Only time I worry about the GVWR. Is when it is only 1000lb more then the yellow sticker.
About RV Families
501 PostsLatest Activity: Apr 24, 2025
