rockhillmanor's avatar
rockhillmanor
Explorer II
Mar 16, 2016
Help needed with cat with UTI
Well, I need some cat advice.
46 years of dog knowledge...cat's not so much!
I have a 20 year old Siamese never been sick in his life.
After full timing with him we are now in our winter house in Florida. I have NO tolerance for a MH or house even having a hint of the fact that a cat lives there. And I am very proud that it does not!
So you can understand why I freaked out when I walked into my house and the smell of cat urine almost made me pass out!
I cleaned the cat litter box. I scubbed and cleaned the area it's in. There all done. Went out and came back later and the same thing. :(
Long story short I 'finally' found out he was going on the floor in a corner under a table .:E And the smell was not right.
Took him to vet. Diagnosis UTI. Interestingly they gave him a shot of long acting antibiotics. Never heard of such a thing.
1.First of all does Anyone have any feed back on using that type of antibiotics instead of pills?
I have him contained in a big soft side crate so I can watch him and chart how much water he drinks and how often he goes. All looks good.
2. How long should I wait before I spring him from his crate to make sure the UTI is cleared up?
3. After the UTI is cleared up will he still be drawn to doing it on the floor again? What makes them not use the litter box when they have a UTI?
Thanks for any help with Sam the Siamese.
  • "1.First of all does Anyone have any feed back on using that type of antibiotics instead of pills?"
    I have had the shot for my feline twice for different items. Great results and no muss or fuss trying to give a pill.
    "3. After the UTI is cleared up will he still be drawn to doing it on the floor again? What makes them not use the litter box when they have a UTI?"
    He will not be drawn to the floor once the underlying problem is solved.
    Clorox Urine remover which is available at Walmart will remove the odor and any stains.
  • Long acting antibiotics are quite standard, especially for cats. Giving an unwilling cat a pill, and getting to swallow it, is, often times, quite an ordeal.
    A UTI in a 20 year old cat is fairly common, especially in a male cat.
    There are several good cleaning agents that contain enzymes to remove odor on the market. Finding everywhere Sam made a deposit will be your most difficult task.
    Good luck!
