WandaLust2's avatar
WandaLust2
Outdoor Catio for when we're away from home.
I wanted share some pics of our Catio. The 5 cats go in and out at will from a cat-door in a piece of plywood fitted to the window. We also have 2 cat-condos, a scratching post and a scratch board in the RV. We do not believe in the mutilation of paws by removing their God given claws. We are in FL for the winter and they need more space than just the inside of the RV. They love being outside in the Catio.
You can see the top of the scratching post on the left bottom and cat-condo on the right. There is another in the bedroom.
  • RV daytrader wrote:
    5 cats!!...I wouldn't want to be on litter box duty!!!
    We share that aspect of cat care. The least pleasant part but it comes with the territory as they say.
    We use two large totes and scoop 4 times a day.
  • magnusfide wrote:
    That's quite a set up. Where do you stow the cage when in transit?
    It comes apart in sections. The wood parts and shelves are stored in the long large cubby in the RV. The wire part rides in the toad with the ground rugs and other stuff.
  • Crowe wrote:
    Very cool! Do you have any room left over for YOUR stuff??? :B
    Good question. ;) We are a bit cramped but spend a lot of time outside and away from the RV. The cat's needs are important to us. :)
    There are also two large litter totes.
  • That's quite a set up. Where do you stow the cage when in transit?
  • Very cool! Do you have any room left over for YOUR stuff??? :B
