Campinghoss@51 wrote:
RCMAN46 wrote:
Suggest you read reviews on Amazon about the Temp Stick.
It appears it has the same issues that my Ring Doorbell products have.
That is disconnects from your WIFI for no apparent reason and can not be reconnected remotely.
I have used Sensaphone systems for over 10 years with no problems. I monitor my summer and winter homes. All that is required is a telephone connection and I am currently using the Verizon home connect for 5 plus years with no problems.
I have had problems described above with the Verison MIFI.
I have been using the temp stik for quite a while with no issues. Most of the time when folks have had problems with connection it was due to the mifi going to sleep. I went
into jetpak settings and set it up to never sleep, no problem with lost connection.
The MIFI I was using was set up not to sleep. But after 3 months the unit went off line. Verizon verified that will happen regardless of the settings.
I guess it must be in the technology or something since that happened to you. Ours is going on 3 or 4 years and we have never had that problem. When we are home I keep ours in the house monitoring just like I do when we had the motor home and now the fifth wheel. When the batteries get low I replace them. I keep it set on one hour when at home but have it monitoring every 15 mins when we travel. I can now understand your feelings towards it.
Safe travels.
I was talking about 3 months of continuous use without cycling power to the MIFI.
