67Cutlass wrote:
RCMAN46 wrote:
67Cutlass wrote:
I've been using AcuRite products for years with very good luck.
We have a PepWave router with built in cellular data card and use the
AcuRite 09155M Access Compatible with Amazon Alexa . This allows us remote access to monitor temps in our motorhome. The AcuRite 09155 can be programmed for temperature alerts that are sent via email.
I have an AcuRite Access at my winter home. Two weeks after I went North for the summer my AcuRite went off line and has not come back in a month.
The AcuRite requires a wifi. I know my wifi is OK as I have a couple Ring Doorbell products on the same wifi and they are working.
I've never experienced your problem. This is the latest from AcuRite which replaced a unit I had for about 6 years.
So far I've been using this just over 3 months and the connection has been rock solid.
Amazon gives the Access 28 percent with one star. That tells me there is possibly a serious problem.
We can only hope AcuRite will address the problems and fix them.
