Deb and Ed M wrote:
winnietrey wrote:
Yes, went with the Herm Sprenger, in three 1 hour walks it has made a night and day difference.
Just throwing this out there, don't know if it is correct. But in a sort of worst-case scenario. I have heard it more than once that, a prong collar can come apart at the worst possible time. (As in your dog is lunging after another dog) Some folks recommend a backup collar.
My first thought is that if your dog is lunging at another dog, even with a prong collar on - you REALLY need some help.....LOL!
The first prong collar I bought had nylon straps that clicked together with a plastic buckle - yeah, I could see that setup failing. But it was also a cheap collar that came with little plastic tips to cover the SHARP edges of the prongs. After the first tip fell off, I threw that one away. The first Sprenger I bought had the traditional choke-chain attachment, but those should be put on by removing a link. Back to arthritic hands (rolling eyes).... so the newest one I have, has a metal clasp and there's a sliding cover that keeps it from accidentally coming open. It's easy to put on and remove without getting tangled in Augie's long ruff. But it was also around $50 on Amazon - quality doesn't come cheap.
Naw not lunging at other dogs so much as doing what your Auggie did in your other post. More wants to play. But that would be a bad time for the Sprenger to fail. (Depending on the other dog) And from what I have heard they do on occasion fail. Which is why I also use the choke chain as a backup. And as I mentioned choke chain is loose and not doing anything, would just be there if the Sprenger failed
Which is why I have it on as well
