Bill_Satellite
Jan 17, 2014Explorer II
OK, Guys, lots of bad info here so let me clarify. The OP DOES have an SK-3005 and not an SK-3003. It's a full HD Trav'ler and all his info is correct. The first few SK-3005 antennas that Winegard built were built on the same base as the SK-3003 and the Dish SK-1000. They quickly realized that their should be a separate base for use with the 3005 and correct this. This was not an issue at all back in '08, it just meant you could not hook up 4 tuners, only 3. Now, with the SWM option you need all 4 outputs to connect SWM. The only resolution I have heard of is running a new 4th cable from the LNB, down the arm and wrapping an external cable around the base to allow for rotation.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
