TNGW1500SE's avatar
TNGW1500SE
3 routers / 1 switch. I have questions
I have 3 routers.
#1 router: Hooked to the cable modem, IP 192.168.1.1. Has some devices hooked to it like my google phone & My Verizon extender, Amazon Firestick. Just my devices that I don't care if they are behind a VPN or those that can't be (like the firestick). I call this my "Dot 1" router.
#2 router: This is my VPN router. Hooks to router one LAN port with Cat 7 cable. Router IP is set to 192.168.2.1 ("dot 2"). All my VPN devices get a IP from this router like 192.168.2."whatever". I call this my "dot 2" router.
Then a 8 port non-POE network switch plugs into router 2 and all the wired PC's plug into it so everything gets a "dot 2" VPN address.
Router #3: Just hooks to the switch and is an access point in my garage. It has a IP of 192.168.2.2 so I can find it on the network. All devices are on it (including WiFi) are on the VPN network.
It all worked great until the power went off yesterday. Then some of my PC's that are plugged into the switch got a IP of 192.168.1.whatever. That's my non-VPN router address. Could the network switch assign that address? I don't understand how it happened. The WIFi cards in those PC's are disabled so those machines didn't hook to the WiFi on the "dot 1" router. No roueter broadcasts the same SSID. How could I end up getting those "Dot 1" IP's assigned when those machines are all pluged into a "dot 2" network? There's no router set in bridge mode. Any ideas?
PS: Adding a 4th soon so I have WiFi down at my gate for a wireless IP camera. It will hook to the Garage access point router and be a wired connection 100 feet away from the garage. Then it can WiFi the rest of the way to the gate. I hope! It's a long way. To far for a Ethernet cable.
  • I would suggest router 3 have a static IP address of 192.168.3.1. Router 2 could issue a IP of 192.168.2.1. See the conflict?
    Richard
  • opnspaces wrote:
    .......If rebooting the affected devices restores them to the 2.1 subnet, then yeah your only answer is in going through the logs of the various routers and see who assigned the IP.
    A reboot is what fixed it. After reboot, everybody got their dot 2 back. I found the problem by doing a cmd ipconfig. The PC I did that on is hooked to the switch and not the garage. That PC has the WiFi adapter disabled too.
    I'm wondering if this will always be an issue if power fails. Maybe routers 2 & 3 would be happier if router one was up and running before they booted. I could power router one off the battery backup to keep it alive.
  • The answer is simple. The power outage caused a device on your network that was configured to not serve DHCP to lose it's configuration and revert back to factory. The harder problem is figuring out who lost their config. You can start looking through the logs on the various devices. You will most likely find the answer there. But there's no fun in looking through logs.
    If you're just mildly curious you could try a test. Do an ipconfig/release and renew or reboot something that erroneously has a 1.1 address and see if it still gets a 1.1 address. If the 1.1 address persists then unplug the Cat7 cable between router #1 and router #2. now do another ipconfig release/renew and see if you still get a 1.1 keep removing items that can possibly feed DCHP, don't forget the garage access point (my suspect by the way) until you finally disconnect the one feeding the erroneous IP's.
    Edit to add... If rebooting the affected devices restores them to the 2.1 subnet, then yeah your only answer is in going through the logs of the various routers and see who assigned the IP.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
