rseymour21's avatar
rseymour21
7" GPS Mounting Locations
Those of you that have a 7" GPS, where are you mounting it?
Any sit on the dash? or use the suction cup to the windshield? Thanks, Ru
  • I cut and bent a piece of sheet aluminum (available in hardware store)into an ell shape. A screw in the dash panel holds it in place. It goes up and bends forward over the dash pad. The GPS mount is stuck to it.
  • I mount ours near the top left corner of the windshield with the suction cup. Puts it out of the driver's line of sight for traffic while also being within easy reach. Only problem with this location is that it is hidden by the sun visor when driving toward a low sun morning or evening.
    A little moisture on the suction cup keeps it from losing suction.
  • Ours sets on the dash on a piece of wood for support. The dash on a Suburban is relatively wide and flat so it works. We tie it on with a piece of wire routed to a defroster vent just in case.
  • We have a 7" that we use with the bean bag mount. The suction cup works for awhile then falls off the windshield, we threw it away. The bean bag mount either sits on the dash or we place it on the engine cover, it works well in both places.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
