timjet's avatar
timjet
Adding a Wingman UHF TV antenna
I may have screwed up. I thought I had a Winegard Batwing antenna and bought a Winegard Wingman intending to improve UHF reception and a Winegard Sensar Pro TV signal strength meter.
When I got the coach home I found out that I have a Braund Concord 90 Electric Antenna.
Is it possible to use the Wingman and Sensar Pro with the Concord antenna?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yes it is possible. the electronics in the head are actually not affected by or affect the Wingman at all. it only affects the "Antenna"
    The only issue is mounting.. I don't know if the needed holes are there.
    "There is no electrical connection between the wingman and the existing parts of the antenna, it only affects the RF (Radio Frequency) pattern of the antenna.. Too much to explain here but I design and build antennas it is a "Director Array" and is not electrically connected to anything.
  • The Wingman is just a passive snap-in wave guide, it will work with any batwing antenna that is roughly the same shape as the Winegard antenna ... attaching it is the tricky part?
    x2 for what Bill says about The Sensar Pro amp.
  • No, it is not. The Concorde does not have the same electronics in the head that are in the Winegard so it will not be of any value. I replaced my Concorde with an electric Winegard but they are no longer available directly from Winegard but might be available from your RV manufacturer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
