MEXICOWANDERER's avatar
Nov 20, 2016
AMAZON LAPTOP BATTERY Ripped Off Again!
Twice in a row is too much. Before salivating cracking your knuckles and preparing a "something's wrong with your laptop" answer - the priginal old battery still charges to 100% indicated but lasts 20 min. A standard capacity replacement acted the same but lasted 35 minutes and self discharged in a week outside of the machine laying on a table
The new extra capacity battery started out charging to 18% on the tray indicator then dropped percentage wise by the day. Now it's at zero and unplugging the brick is instantaneous shutdown with erroressage upom restart. The battery in direct 12.0 volt recharge refuses to take 5 milliamps right to the prongs.
Can I make a cost effective separate battery input for the nightmare? A ox with a handle and roughly 20 volts supplied perhaps at a 10 amp hpur capacity? Lugging around an AGM battery and inverter for the brick is rubber-room grade rationale. The recharging of a home brew 19.5 volt battery is right up my alley but the lithium ion battery source is not. Yes I know the pecularities of lithium ion overcharge and undercharge and current limits.
One source wants seventy dollars plus shipping for a "guaranteed original" battery for the Gateway. I may even have to settle for Nickel Metal Hydride. But 10lbs battery weight is the limit.
Some hot spots in Mexico do not have an outlet within a hundred meters.
  • It's actually pretty simple: don't like Amazon, which appears to be the case with all the carping you do about them, don't buy from Amazon. I don't like Amazon, well I don't like Jeff Bezos to be exact, but sometimes they are the cheapest place to buy products, not always but frequently. When I've had issues with what was shipped to me, it has been dealt with quickly and easily.
    You complain incessantly about how difficult it is to get things shipped to you, but you live where you live of your own free will. Deal with it.
  • MEXICOWANDERER wrote:
    Amazon acts ah ho-hum...
    Throw another log on the fire...
    Like lifetime warranty garbage alternators and starters. But for me it is a 400 dollar 5 day 1,300 mile round trip. Or I can pay 200 dollars shipping9 and only drive 1000 miles to the nearest FedEx office.
    There must be a voltage acceptable span. 19 volts and a 4.0 amp brick. Sixteen NiMH D cells?
    Zero ethics and zero monitoring. Talking about setting up the market for an insanely bureaucratic government monitoring monolith. E CAVEAT EMPTOR passa da hookah...
    Did you actually buy from Amazon, or from ANOTHER vendor on Amazon?
  • Amazon acts ah ho-hum...
  • my first laptop many years back
    i took the battery pack apart and rebuilt it using Nicads bought at allelectronic
    the oem cells were also nicads,
    but yes you can rebuild it
    and a $5 drock bucker/booster will let you create any charge rate you need for the NEW battery pack
  • Are you sure Amazon is to blame? When you hit the buy button you can see if the item is sold and shipped by Amazon or an outside vendor.
  • If it an older laptop, then it is likely a "new old stock" battery.
    I have had 2 like you are talking about. Thank God for Amazon Prime for no hassle return.
  • Hi Mex,
    What is defeating you is the energy management system that is installed in the laptop battery. It only takes one bad cell for the battery to be bad. (This is another chance for you to complain about "smart" chargers LOL)
    I wonder if you could not use Nicad's. Of course the LI charger could not be used. NMHydride also work but both have that dratted memory effect and both grow dendrites.
    I used to have an Amstrad that used C cells. 12 of 'em! It did not take me long to go to Nicads.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
