YC_1
Jul 06, 2016Nomad
I would definitely find the wall plate and see if it lights up. Even if it does the voltage might not be getting to the amp in the antenna if a connector is loose. It is 12 volts so it will not hurt you so unplugging the coax at the antenna end and measuring it is easy.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
