mike-uswest's avatar
mike-uswest
Explorer III
Jan 30, 2017
Another Dish ??
Continuing from my last question: We have gotten switched over from DTV to dish at the house. So far so good. I found a satellite the same as the one that they put on my house and I will use that one with the kitchen TV and Wally receiver when I travel into the wilds with a tripod. The dish is a Dish HD, I believe a 1000.2 or close. It has no coax to it but I have some I can use, including the one that was on the DTV dish that I had used until now. I found a good set of instructions to setting it up with, the three LNB's and all. It was talking about using a dpp44 switch to hook to the three coax from the LNB. They are a little spendy. My question is , when I looked up what programs come in on what satellite most all come in on 119 with some on 110, 129 seems worthless. Could I just hook up the one 119 LNB and work with that, or, could I use a reverse coax splitter, two in and one out to hook up 119 and 110? I am trying to make this as simple as possible. Thanks.
Mike
  • wingsfan20 wrote:
    All HD locals are on 129.
    Not true. Though OP get his locals out of Medford, OR which uses sat 129, this is not the case for all DISH locals.
    Just check The List.
  • You dont need the DP 44; a sw-21 ( I think) will work for under $15. My installer gave me one. Its got two inputs, one output.
  • I have a 1000.2 in addition to our Tailgater. When I use the 1000.2 I get all 3 sats without any additional switch.
  • Channel 129 is where the majority of HD comes from. All HD locals are on 129. Don't need the DP44 switch. Just connect to the 119 LNB and run check switch from the setup page on dish. I get all three using one coax from 119.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Oct 16, 2025
