Tomboy2's avatar
Tomboy2
Another Hopper question
I am a snowbird that currently has a VIP222 Dish receiver. While traveling I connect "antenna one" to my crank-up Winegard dish ( I am aware of the limitations of this set-up). When parked for the season I use a Dish1000 on a tripod. I connect TV1 via HMDI and TV2 via AV cable (the red, white, yellow).
Can I connect a Hopper to my crank-up when traveling? and can I independently view two different channels when parked (as I do now with the VIP222) via HDMI and AV cable?
  • Tomboy2 wrote:
    Dutch, will the Hopper work as a single tuner receiver with the legacy LNB while traveling? My 222 is limited to only one sat with the roof top crank-up dish, and this is fine for overnight or two day stops. When parked for the season and connected to a Dish1000 on the tripod will it function as the multi-channel DVR that it is supposed to be(although with only mirroring capabilities to TV2)?
    My crank-up rooftop dish works fine with my VIP211k, but not with my Hopper 2 so far. I use a tripod mounted 1000.4 with interchangeable eastern and western arc LNBF's for both receivers most of the time. Sometime I'm going to try connecting just one of my DPP LNBF's without aiming it, and connecting the rooftop dish to the port 4 input as if it was a wing dish. I don't know if that will work without it seeing any other sats though.
  • Tomboy2 wrote:
    When parked for the season and connected to a Dish1000 on the tripod will it (Hopper 1 or 2) function as the multi-channel DVR that it is supposed to be?
    Yes, and you can also hook up your VIP222 receiver:
  • Dutch, will the Hopper work as a single tuner receiver with the legacy LNB while traveling? My 222 is limited to only one sat with the roof top crank-up dish, and this is fine for overnight or two day stops. When parked for the season and connected to a Dish1000 on the tripod will it function as the multi-channel DVR that it is supposed to be(although with only mirroring capabilities to TV2)?
  • The Hopper will not work as intended with your single LNB crank up dish. The Hopper requires a DPP double or triple LNBF or switch to feed the three tuners in a Hopper 1 or 2, and a hybrid LNBF to feed the 16 tuners in a Hopper 3. As said, you'll need a Joey to feed the second TV with different channels, although the Hopper can be set up to mirror the primary TV. The Hopper 3 hybrid LNBF fits the 1000.2 dish, and can be fitted to a Winegard Trav'ler automatic roof dish (WA only) with just a bit of fiddling to make it work. It can also be fitted to a 1000.4 dish with a bit of mechanical fiddling.
  • Could well be wrong (wouldn't be the first time) but I believe the hopper serves the primary TV and you have to have a Joey for each additional TV.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
