deepdoc1's avatar
deepdoc1
Antenna Spring Questions
Howdy. I have a Wilson 4G Omni-directional outdoor antenna to mount on the roof luggage rack tubing on my motorhome. The antenna comes with a sheet metal mounting bracket that screws to the base of the antenna. My concern is driving under low hanging branches and possibly knocking it off.
I have seen spring mounts for CB and other antennas, and Wilson has a truckers antenna that has a spring, so I am wondering about adding a spring to my setup.
Firstly, I am not particularly knowledgeable about this sort of thing, so keep that in mind. The
antenna I have is 75 ohm and the coax connects directly to the antenna. If I screw a spring to the antenna coax connection, how do I then connect the cable? Is there a pass-through inside the spring?
Or do I have it all wrong in my head about how this works? Any ideas appreciated. Thanks in advance.
Jim B.
  • Thanks for the replies, I think I have the idea now. I'll make up a revised bracket to use probably a light duty antenna spring, and mount it on the driver's side. When counting the height of the railing on the roof, the antenna does stick up a little higher than the a/c, so a spring will give me some extra comfort level.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    To Spring mount that antenna you will have to remove the existing mounting bracket and make another one that is flat. No bend. The new bracket needs to have 4 holes. 3 matching the 3 that attach to the Unit and you need to have the plate extend out one side a bit and drill a 3/8 inch hole (or about a 1/32nd larger) there.
    Now a 3/8 Fine thread as I recall bolt goes into the large spring, and it mounts with a 3/8 Fine stud to a new mount. (Ball type) you will need to get at a CB shop.. That's for the big spring.
    Small spring 3/8 becomes 1/4 as I recall.. but check the spring.
  • you would have to add a spring to the mount
    not to that antenna
    that is a good antenna, folded dipole no ground plain plate needed
    where on the roof rack is it mounted
    street/drivers side is safer than curb side
    or you could get one of these
    this is what i have, but i put it inside the overhead cabinet on the drivers side
    it does need a steel/iron surface to stick too, has a magnetic base
    the bracket from antenna is probably steel, but its too small a surface area for a proper ground plain
    a vehicle roof car/truck or something like a 12" serving tray/scrap metal plate
    spring loaded multi-band wilson cellular booster antenna
  • No, adding a spring to the coax will change the characteristics.
    If you wanted to add a spring you would want to connect it to the metal mounting bracket.
    This antenna is not that tall so I suspect you would be taking off other items on the roof if limbs are an issue.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
