1492's avatar
1492
Moderator
Jul 18, 2013
Any DSLR/SLR Lens Experts?
I have a Nikon 70mm-300mm SLR lens that's basically not zooming. I can't adjust the focal length which is apparently stuck at 300mm. The manual focus works fine. The zoom ring moves normally, just not adjusting the lens focal length internally? Any ideas or fixes?
It's an older SLR AF zoom lens, so not worth servicing. I'm using it on a Nikon DSLR.
  • That's also what I'm thinking, though wanted to see if there is some common glitch with these lenses, or some user fix. I can likely buy a used replacement cheaper than it would cost to have it serviced.
  • I've alway used respected local repair shops, Detroit, Orlando, Chicago, but it's been quite a few years, so I don't know who is still in business, and my repairs have all been Canon, Olympus and Leitz, the Leicas going to factory for rebuild.
    Lens repair is usually flat-rated for disassmbly, cleaning, lube, minor repair. Maybe under $100 to service a zoom, to several hundred dollars depending on complexity of optics and movements, andnthings like internal motors and weather sealing.
    Nikon has a list of authorized repair stations, but for your zoom, they may want to do the work themselves.
    Your problem is likely repairable, probably a tab out of a slot in the zoom mechanism, but you have to figure out what the lens is worth to you, weigh the repair costs vs replacement. The low prices of some of today's kit lenses sometimes make repairs of more expensive pieces questionable, it not really a high value lens.
  • You can try cleaning the contacts, but I doubt that will work. If it isn't zooming when you turn the zoom ring, there is probably something mechanical inside the lens that has broken or come loose. Either way, it probably isn't something you can fix and probably isn't worth sending off have fixed.
  • Did it work before and now it is not?
    If so, sounds like the motor. Clean the contacts on the lens and the camera and try again. If it still doesn't work, sounds like it costs more to fix than replace.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
