- PSD_w__Lance_84ExplorerWas hoping to just replace the lens but a closer look at the plastic base showed it was brittle and cracked in several areas. I ended up replacing with an Amazon led version.
- ticki2ExplorerTake the light off and see if the are 3 holes with wires or one . If 1 it’s probably original , if 3 it probably originally had individual lights .
- mkirschNomad IIGoogle "amber identification light bar." You're not going to find an exact match, I'd imagine.
- PSD_w__Lance_84ExplorerOpps, it's a 2003, not 2002. I bought it new in 2003 and the Lance brochure for that year shows the same long marker light. Would like to replace it with another "long" one but still can't find one approx. 12"-14" in length.
- Ramblin__RalphExplorerMy 2001 845 also has 3 separate covers, spaced widely apart.
- JRscoobyExplorer IIWhoever made the light likely put name or trademark on it somewhere.
- joerg68Nomad IIIThis is the Lance brochure for 2002:
https://www.lancecamper.com/docs/2002-brochure.pdf
All of the campers in the brochure have three individual clearance lights in the center, so did my own 2002 Lance 915. The lights on your unit may not be the ones that came with the camper originally.
