dbbls's avatar
dbbls
Anyone use a Dish Tailgater?
If so, how do you like it? I have heard it does not work as good as the Dish 500. Does it give a good picture all of the time and how does it do in the rain?
  • If you can afford it, I would go the extra $100 or so and get the Pathway X2. Same automatic setup as the Tailgater, but considerably larger antenna inside, and much more robust construction. Also has the advantage of using the southeast satellites as well as the southwest ones if you have a better shot at them. You can hook a second receiver to the Pathway, but it has to tuned to the same satellite as the other receiver. We got fed up fussing with the Tailgater, and traded up to the Pathway X2, and it picks up the satellites much easier. Set up side by side with each other in the Keys, the Pathway was showing a 50% stronger signal than the Tailgater.
  • I've had a Tailgater/VIP211K for over two years now. When it works, it works well. The only issues I have are:
    1) About 50% of the time tree canopy in campgrounds cause either no reception or only 2 out of 3 satellites.
    2) If you don't use it for greater than 30 days you get a 'Not Authorized' error. You have to call Dish and get the error corrected.
  • Very happy with ours after 3 yrs. Works well. Receives HD fine. Just like the home set up, it will lose signal when a heavy rain moves over.
  • We have one, no problems once you understand it.
    It finds the satellites just fine .. provided you have a really clear SW sky (no trees). We love ours, especially after struggling with a dish on a tripod for a while.
    One thing, once it homes it, if you change channels from normal to High Def, the Tailgater has to reposition itself to find the HD satellite. It takes a few moments when changing between channels. If you stay off HD, it's much faster. It also help if you know the satellite number and the transponder number for that station when it seems to take too long.
    But for the most part, we enjoy ours very much, and it's much easier to set up than the tripod version. (although the tripod version has 3 eyes, it's still wired for only 1 eye at at time, so I have it set on the HD one.) It had limitations this way, so for us the Tailgater is much nicer ... a little slow sometimes, but much nicer. It always brings the channel ... just have to be a little patient.
    edit: We've not had any problems in Rain, unless it was hurricane force rain! But then, we were home and even the dish on the roof of the house wasn't working either because of outlandish heavy rain.
  • We have used one for two years.
    It does not work as well as the Dish 500 but is much easier to setup.
    Biggest problem we have seen is on HD channels the picture pixelates more frequently than it does with SD channels. So we tend to switch to the SD channel if the pixelation gets too bad.
    We haven't had a lot of rain while using it so can't answer but I'm guessing in heavy down pours there will be loss of signal.
    I did set it up once near a flag that we fly and when the wind started to blow the flag was affecting the signal. I moved the tailgater and that fixed the problem.
    For me it saves time so I'm willing to put up with some picture issues. I would say 95% of the time it is as good as the Dish 500.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jan 03, 2024
