mikeleblanc413's avatar
Apr 18, 2014
Are All External Hard Drives Created Equal?
I have two WD external hard drives...dinosaur's by today's standards...they're large...like a big book...I notice that many of the newer ones are not much larger than a pack of cigarettes and run strictly from a USB port. My dinosaur's have to be plugged in electrically. I'm looking for a 500G device. Are they all created equal? What is working best for you? THANKS!
  • I used both the smaller "passport" drives and the 'MyBook' desktop drives from WD. the 'passport' serves as a travel drive with our laptop as well as our emergency backup drive that is stored in our safe deposit box. I use the 'MyBook' drives for home use.
    words of caution. the 'passport' drives work well with the supplied USB cord. if you try to use it with a longer cord it may not work at all. and be sure you select a drive to match your USB port. many/most but not all USB drives are backwards compatible. that is a drive that is advertised as USB3 compliant likely will work on a USB2 port...just be sure before you buy.
