lynndiwagon's avatar
lynndiwagon
AT&T Unite Hotspot Port Forwarding
Just got a new IP Camera and trying to view it through an AT&T hotspot from my Cellphone. I can see the video on the local LAN but can't seem to be able to see it remotely. I have a feeling that AT&T doesn't allow remote viewing through their wireless networks. Calling them is a lesson in frustration. I know how to port forward, DNS Services, etc. and can see the camera through my Uverse router at home. Has anyone successfully been able to access an IP camera through an AT&T hotspot?
  • Port Scanner in the Google App Store. It will scan ports on a remote computer. If you want to scan the ports on your android you'll need to run a scanner on something like your PC and scan the Android.
  • Which leads to the next logical question:
    Has anyone written a port scanner for iOS or android?
    Found Port Scan for iOS
  • If you know how to do port forwarding, map the output to a different port. Many ISPs block or filter traffic on well-known ports which are typically those below 32,767.
    Services like Torrent default to use these lower port numbers, and since "they" think the only purpose for Torrent is to steal music and videos and by blocking these ports they lock out Torrent applications. However by mapping to use higher port numbers one can get these services running again so it can be used for otherwise legal purposes.
  • The hotspot is in the RV, or in the house
    For sending out from home or for receiving in RV
    Are you trying to check RV from home
    Or check house from RV
    I know cellphone data contracts, stipulate NO ..remote viewing equipment monitoring aka 24 hr continuous access not allowed
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
