- KansasRVExplorerditto on using some sort of hood.
- vandaveExplorerThanks
- GordonThreeExplorerSave the empty box next time you finish some crackers. The light cardboard is easy to work into a shade for the screen. Stick it on with painters tape or blue tack.
If you like the function, use it as a template for some plastic or aluminum sheet... Or keep the cardboard. Paint it matte black with a rattle can and call it done. - Bill_SatelliteExplorer IIAssuming you are getting glare on the monitor inside the RV the only real solution is a hood of some kind. Many manufacturers produce these but if not you will need to fabricate something to keep the sun off the screen.
- vandaveExplorerMy bad. I should have been clear. I'm talking about inside the rv.
- scrubjaysnestExplorer
Johno02 wrote:
Try cleaning the window over the camera.
Tried this and didn't work for us. We have glare all the time, starts at the back of the dinghy, JK Wrangler, and further back. I'm think it needs a shield above the camera. Mirror cams work much better. - Johno02ExplorerTry cleaning the window over the camera.
- Bill_SatelliteExplorer IIWhen do have glare problems? The only time I had that kind of an issue was when traveling early or late and the sun was low and behind us.
- RoyBExplorer IIIWe have very poor use of our backup camera being used at night...
They need to be mounted as high as you can get them and then pointed down at a good angle...
Like shown here on this google photo...
google image
Roy Ken - Home_SkilletExplorer IIFrom the ladder?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
