- trb46ExplorerI just gave up our landline this week and went with MagicJack Plus. WalMart has dropped the price to $49.95. Installed quickly and voice quality is excellent. I have not had one telemarketing call since I installed it; I was getting around five unwanted calls per day with the landline, despite being on the DNC list. DISCLAIMER: I am not an agent for MagicJack, just a satisfied customer. Your experience may be different.
- 1492Moderator
phranc wrote:
IF 'Basic Talk' is similar to Verizon's 'Home Connect' , then it would work well.
I believe Verizon Home Connect uses a dedicated mobile data connection, whereas, Basic Talk requires a separate net connection. - phrancExplorerIF 'Basic Talk' is similar to Verizon's 'Home Connect' , then it would work well.
- K_CharlesExplorerWhat if you need a land line to get on the net? How well does magic jack work then?
- powderman426Explorer
michael8rc wrote:
Get a magic jack. After the initial purchase price it only costs $29.95 a year for service. Have been using one for over four years and no problems.
X2. The Magi Jack works well and is the cheapest service out there hands down. - 1492ModeratorCheck your net connection for VoIP suitability. Speed is generally not the issue. VoIP generally requires about 1/5 or less the bandwidth of most streaming videos. The real issues are latency, its associated variations called jitter, and packet loss which will most likely effect your line connection quality more so than speed.
You can use an online service such as myspeed.visualware.com. Requires Java enabled in your browser. - burlmartExplorersorry, meant to say to replace landline
- Tom_NExplorerVOIP is a poor choice for RV use. One would need high speed internet access. If that was through a cellphone service one would be better served by just using a cellphone.
- michael8rcExplorerGet a magic jack. After the initial purchase price it only costs $29.95 a year for service. Have been using one for over four years and no problems.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
