- bigjohnmcvickerExplorerAll the above are true. Also just as important is knowing if you are in an area that gets good reception. Heres a link to find out http://transition.fcc.gov/mb/engineering/dtvmaps/
Also only older bubble front TV's need the box. The newer slim ones do not. Theres info on that website about that also. - camperpaulExplorerIf the set was built before 2010, it is possible it does not have a built in digital tuner, in which case you will need a converter.
You would better off buying a High-Def LED/LCD digital TV set. - Super_DaveExplorerDo all tv's need a digital tuner? I thought just the really old ones did?
- sch911ExplorerThe TV must have a digital tuner.
The batwing amplifier switch must be on.
You then need to set the TV input to "Antenna", and perform a channel scan. - nomad297ExplorerPower up the amplifier, then do a channel scan on your TV.
Bruce
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
