enblethen
Nov 28, 2014Nomad
Doubt whether the range is the issue. It is more apt to be the sheeting on the garage. Mine has metal and it blocks the signal. I have problems with garage door opener as well The metal blocks the signal.
I am going to extend the garage door opener antenna via an insulator to the exterior of garage. Not sure if wrapping a small copper wire around the remote unit , extending out side would induce the signal sufficiently to increase the signal
I would look for a remote sensor that has an external antenna connection.
Another way is to mount the transmitter on the outside of the garage with the probe going inside.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
