LouLawrence
Mar 06, 2022Explorer II
If you want DirecTV then you really only have 2 choices as ALL of the dome style antennas limit your viewing to SD only, NO high def. channels.
So, for DTV and HD you can use a standard home style DirecTV antenna mounted on a tripod which you manually setup, locate and point at each new location or a fully automatic home style DirecTV antenna mounted on the roof of your RV. Winegard has a unit called the Trav'ler and RF Mogul is called the Eagle. The Winegard is expensive and the RF Mogul is even more expensive ($2000+ ish installed).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
