LittleBill
May 05, 2013Explorer
if you just want to use a different wifi password, the easiest is to change the password
short of that, simply plug 1 of the new routers into a switch port on the existing router, and plug that into the internet port on the temp wap, then simply setup the router like normal, pick a new ssid and password and should work fine
try to pick a different channel then the one you currently use
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
