greenno
Dec 28, 2022Explorer
Lithium battery box temps
Evening gents I was wondering if anybody monitors their battery box temps in freezing weather?
Built up earlier this year two 280ahrs each LifePO4 battery's for my AF990 giving me a total capacity of 560ahrs.
So now that it's a bit colder and I plan on being places that will be freezing this winter Im thinking of a good way to help keep them warm during the nighttime.
When I built the battery banks I placed on the bottom of the battery pull-out rack some 3/16" foam board to set the new batterys on. I also installed on all four sides of each battery the same foam board. After I made all my series/parallel connections from them I also made a lid out of , you guessed it, the same foam board.
So my idea is this.
I have good access to the box itself by just removing the two sliding drawers and the cubby storage insert next to them for easy access. Also have access underneath the sink area.
So I just ordered small 12vdc fan (40mm x 40mm x 20mm) which I will drill a hole into the top rear corner of the box and mount the fan directly on top of this.
I also ordered a 12vdc digital temp controller that I will probably mount underneath my Solar Charge Control panel on the wall in back of the sink.
I will set the temp to probably 40 degrees or so to run the fan to circulate the warmer cabin heat in that compartment.
In the back section of the cubby storage insert I will cut/mount a 4" round vent cover to xor heat from the cabin into the space underneath the counter area.
Not sure how much difference this will make if any but total cost for all materials is under $40.
Going to replace the white 4" round vent cover that is currently installed in the step to enter the bathroom.
In back of this vent is already a fan that kicks on when the gas heater runs. I will probably install a switch for that fan also so if Im not using the propane heater and using a 120v model I can still run that fan to circulate in the valve shut off area. Good thing I checked that today as one of the connections was not connected properly and the fan would start/stop if you moved the wires. So much for QC.
Parts and materials should be here in the next week or so so I'll take a few pics and relay any pitfalls or issues that come up and then try to see how much difference this little project makes.
Stay tuned.
So my idea is this.
Stay tuned.
