Bill_S_1
May 05, 2013Explorer
LittleBill wrote:
if you just want to use a different wifi password, the easiest is to change the password
short of that, simply plug 1 of the new routers into a switch port on the existing router, and plug that into the internet port on the temp wap, then simply setup the router like normal, pick a new ssid and password and should work finethen simply setup the router like normal, pick a new ssid and password and should work fine
try to pick a different channel then the one you currently use
Bill, I am not clear on the second part of your suggestion. Are you saying that there should be 2 cables connecting the main (Verizon) wireless router/modem and the (D-Link or Netgear) spare wireless router that I would use as a WAP?
I was under the impression that I could take a D-Link 614+ for example, and set it up as a WAP, then plug it into a port on the Verizon modem/router. No?
I did that, and it works, but I think there could be some sort of conflict. I took a D-link614+, and plugged it's WAN in, to a LAN jackon the Verizon. I can log in to the D-Link, and have internet access, but when it refreshes, or whatever routes do, I'm thinking that it may issue an IP address that is also being issued by the Verizon router.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
