River-Runner's avatar
River-Runner
Blu-Ray for Data Backup
I want to use my Blu-Ray burner to backup my PC data. I have a 3 TB data HDD and I want to use 100 GB discs to make hard copy backups for offsite - I also do an external HDD..
Does anyone have a blu-ray backup program that you can dump say 2 TB of data into the hopper and the program will chew through 100 GB discs, one after the other - automatically - until a complete backup is complete. I used to do this with Roxio on CD's, sometime more than 20 CD's - but I understand Roxio isn't the same - one site said it is full of bloatware.
Please recommend a program that will provide for automatic blu-ray backups.
Thanks -
    Thanks -
    NERO Burning Rom has a backup feature, you point it at a folder or drive, and it tells you how many discs.
    100GB is the new BDXL format, make sure your drive supports triple-layer discs BDXL discs before buying those expensive pieces of plastic :)
    For what it's worth / JMHO:
    A single BDXL disc is in the neighborhood of $40-50, compared to a fast 1TB hard disk or slow 3TB drive around $100, you might want to consider them as an alternative.
  • I can't answer your question. I just know I'd keep an external hdd off site too. Just curious why you want to go through all thoes disks when you can use another hdd
  • Don't know much about the software but I'd recommend you consider using an external hard drive for offsite storage. Much cheaper in the long run. I have one that I keep in my home located inside a safe and one that I keep at offsite at work.
  • My goodness, that's a lot of data. What is this, a Google server?
