ktmrfs
Mar 22, 2017Explorer III
Bill.Satellite wrote:
The WAZE app would likely have given you the exact same information in real time (likely where On-Star gets their information) about the traffic. You would have needed to look at a map to ensure the re-route plan would be on roads you would be happy with.
very true. The Waze app wasn't around when I ran into the problem on I-90. and google maps will usually give you some traffic info as well. just not the detail that WAZE or onstar can give.
Also XM radio has a traffic app that is pretty decent as well for traffic incidences. At least with XM "all" you need is a clear view of the southern sky. I use "all" in quotes because that isn't as easy as it seems in many places.
The other problem with WAZE or onstar is they only work if you have cell service. Onstar is now ATT so if your out of GSM range, no way to contact onstar.
Our phones are verizon, so between the two, it helps. often one or the other has service in places we often go. but not always.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
