gbsb's avatar
gbsb
C B Radio Help
I know hardly any body uses a cb any more but I put one in for a trip with several other rigs that are traveling together and we can all chat back and forth. I bought a new radio and antenna mounted it in my truck put the antenna on the mirror and drove over to the interstate to see how it would do. Nothing a little static but do not hear any one talking. I have a truck camper so the antenna is not above the camper but I should hear a trucker say something. Does the radio frame have to be grounded, does the antenna need to have a ground? They are both mounted to plastic. I thought the antenna grounded threw the coax and the radio grounded threw the power wire. I have not had a CB since the late 70s so do not have a clue anymore, can some one help. Thanks George
  • the mirror is the poorest location.. but sometimes there is little other choice.
    Run a heavy gauge wire to the base of antenna and to a body fender/frame.. NOT THE DOOR...
    radio frame/case does NOT need a ground. just the black wire.
    also antenna or radio could be defective... should hear something/someone.
  • wnjj's avatar
    wnjj
    Explorer II
    Find someone else with a CB to test it out. Most of the time there just isn't anyone talking,
    Truckers generally only use Channel 17 and 19.
  • ScottG wrote:
    The ant needs to be grounded, preferably to a large metal area. It should work if mounted to a metallic, tubular mirror bracket. For transmitting it's important to tune the ant but it should receive ok as-is.
    I would double check that the base of the ant is connected to the vehicles body/ground. Any chance your mirror bracket is rubber mounted and isolated electrically?
    It sounds like your antenna is isolated from the vehicle. Find someone with an swr meter.
  • The ant needs to be grounded, preferably to a large metal area. It should work if mounted to a metallic, tubular mirror bracket. For transmitting it's important to tune the ant but it should receive ok as-is.
  • Go to a local truck stop and sit around for a bit. Actually, now there is very little conversation between truckers on the CB while out on the road. There is a bit more between then at truckstops. Most OTR truckers are on cell phones with wireless headsets.
  • The Radio is a Uniden PC78LTD, antenna is 3 foot stick with mount and coax 1000 watt. Mounted to the drivers mirror on a F450 Ford.
  • Models would be helpful. Typically there would have to be to a ground of some sort.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
