mbutts's avatar
mbutts
Cable TV not working, Antenna working
Hi,
I've used the cable connection successfully in my TT approx. three times in the past three seasons. At our first outing this year, the channel scan would run for 10-15 minutes, then only show really snowy images without audio on a single channel.
All connections were verified to be connected and the KOA worker verified there was a cable signal at the box.
Here's the six combinations I tried:
Television set to Antenna, TT antenna switch set to CABLE, ANT, or OFF. After a new channel scan, receives 5 local over-the-air stations.
Television set to Cable, TT antenna switch set to CABLE, ANT, or OFF. After a new channel scan, snowy, fuzzy image on a single channel.
Any diagnostic suggestions?
  • Bob,
    The plate has no button, just the selector for ANT, CABLE, or OFF. I tried it in all three positions without success.
  • Sorry, forgot to mention that the antenna is a Jensen omni-directional.
  • Is there a red button on the plate where the cable to the TV? If so push, an try again.
