- Chris_BryantExplorer IIMaybe I'm missing something, but I just use iTunes. File -> add file to library or add folder to library. Then drag the files I want to the iPad icon. Can be done tethered or Wifi. This is for pdf files only, but I put them in a service manual folder in iBooks on the iPad.
Sure beats dragging a ton of service manuals in the field. - TheBearAKExplorer
Fizz wrote:
The only use for that adapter is to transfer pictures. NOTHING ELSE.
Until it was hacked by several apps in the app store...
Watch the YouTube video I linked. - mr__edExplorer
1492 wrote:
mr. ed wrote:
By "lightning connector" do you mean the tiny plug that goes into the iPad ? The end that goes into the charger appears to be standard USB
It'll be rectangular connector if you have a current iPad. Otherwise, a flat 30 pin connector for past models.
Mine matches the picture on the left. Thanks.... - 1492Moderator
It'll be rectangular connector if you have a current iPad. Otherwise, a flat 30 pin connector for past models. - Take a look at the photos on this Apple page. You'll have to scroll down to the Connectors section.
http://www.apple.com/ipad/compare/
My iPad2 has the wide 30-pin connector. It looks like the other models have Lightning. - mr__edExplorer
Tiger4x4RV wrote:
mr. ed wrote:
I have one further question: is there an adapter available that allows me to use a thumb drive with my iPad ? Thanks again for your support.....
If there is, the Apple Store has it. Does your iPad have a Lightning connector or a 30-pin?
Link to Apple Store Cables & Docks page
By "lightning connector" do you mean the tiny plug that goes into the iPad ? The end that goes into the charger appears to be standard USB - FizzExplorerThe only use for that adapter is to transfer pictures. NOTHING ELSE.
- SCVJeffExplorer
TheBearAK wrote:
And make sure you buy what tou think you're buying because there are two adapters: one with USB, and one with a SD slot.
More specifically, you want the USB camera adaptor.
Then you need an App called iFiles ($4)
https://www.youtube.com/watch?v=KSHEY4mwMV0
Or you can buy one with both for $5 delivered from China - TheBearAKExplorerMore specifically, you want the USB camera adaptor.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
