Bill_Satellite
Apr 05, 2014Explorer II
If you are using a different kind of antenna than you have in your home you will need to go through the required Check Switch routine to get the receiver setup for that particular antenna. If you are not using the same LNB setup that you have at home you may not get all of the your channels either.
A few more details might help get you some better guidance.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
