dougrainer
Apr 05, 2014Nomad
The simple answer is NO, the inputed Zip Code has no bearing on receiving the signal. The Zip is to aid in aligning a home type dish. The receiver will tell you the Azimuth and Elevation for the Zip code you are in. As another stated, IF you are in a specific area, some of the channels may be "spot Beamed" and will only hit the small geographic area you are in. Once you leave that Spot beamed area, you lose those channels. Doug
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
