way2roll
Aug 25, 2020Navigator II
Can I put my SIM card in other devices?
My company has a corporate deal with ATT so I get really good prices on truly unlimited data. Our new FW has the connect anywhere system, which is basically a built in hospot and router/brodcast to provide wifi inside the camper. It controls all the systems in the RV from my phone and allows for remote monitoring as well. You can activate this with whatever company you choose and I could call ATT and activate it through them. But why confine my hot spot to the FW? If I have a mobile hotspot, can't I use that when not in the FW and then take the SIM card from the hot spot and install it into the connect anywhere system in the FW? Basically use the same SIM card and swap between devices? Do carriers know or care what device the SIM card is in and will it work?
Further, if I have a VZ hotspot for duplicity (I work remote) can I swap that into the FW's system too.
Maybe it doesn't matter and it's a moot point, but my thinking was that the built in system in the FW with antennas in the rv will have a stronger broadcast signal than the hotspot. Maybe it doesn't and it's not worth it.
