BB_TX
Jan 09, 2014Nomad
cooperwl wrote:
How hard is it to use the 507 system with two different trailers if they are both fully equipped with sensors? I would like to setup my truck and rv (6+4=10 sensors) but alternatively tow my utility trailer equipped with its own four sensors. Will I have to totally reprogram the system each time I switch trailers?
If both trailers have sensors on all wheels, you should be able to program both trailers the same (i.e. sensor numbers in the same wheel location). When you hook up a trailer the receiver is not going to know which trailer it is, just that there are 4 sensors back there transmitting signals. Contact TST to make sure that is doable.
You would probably need the trailers some distance apart when doing the programming so that there was no overlap in signals.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
