Dutch_12078
Jan 10, 2014Explorer III
cooperwl wrote:
How hard is it to use the 507 system with two different trailers if they are both fully equipped with sensors? I would like to setup my truck and rv (6+4=10 sensors) but alternatively tow my utility trailer equipped with its own four sensors. Will I have to totally reprogram the system each time I switch trailers?
A friend of ours does essentially the same thing in that he tows two different toads, both equipped with TST sensors. The way he handled it was to set up the sensor positions as if the "trailer" had dual wheels on each axle. One toad uses the inner dual indicators, and the other one uses the outer duals. The only minor downside is the blank readings at the positions that are not in use as the display sequences through.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
