dons2346's avatar
dons2346
Cannot access Yahoo UPDATED
This is strange. I cannot access Yahoo with any computer I have. I am using a VZ mifi 4510L and can connect to other websites with all computers, tablets, and phone. By using the phone as a hot spot, all machines can access Yahoo. Any ideas?
  • The Texan wrote:
    MyYahoo.com which is my home page and access point to my yahoo mail. No error msg, just won't do anything.
    on the off chance that you did make a grammatical error the web address is actually my.yahoo.com, not myyahoo.com. give that a try...otherwise try clearing out your cache, temp files, etc. if you're using internet explorer you can do that...
    TOOLS:INTERNET OPTIONS
    for ie10 click DELETE in the box about 2/3 of the way down. earlier versions should be something similar.
  • Here's an idea to rule out one problem. When you're using the phone as a hotspot, bring up a command prompt and ping myyahoo.com. Write down that IP address.
    Then go back to the mifi connection. Open a browser and instead of putting in myyahoo.com as the address, use the ip address. If it works with the ip address, you have a name resolution problem associated with the mifi.
  • I don't know what yahoos problem has been. I gave up and set up a second account with gmail. My pass word would't work with yahoo. Strange because Verizon and ATT email uses yahoo and never a problem but going to yahoo email it goes tilt quite often.
  • I stopped using them as my homepage when they changed to the new format but when I just tried to connect and it came up okay. I am using a Verizon 720 aircard and Cradlepoint MBR95 router.
  • dons2346 wrote:
    rk911 wrote:
    what error are you seeing? are you trying to access yahoo.com or mail.yahoo.com or some other variant?
    All I get is "unable to connect" I get this trying for home page or mail. It all started Friday night.
    Funny thing is that if I use my phone as a hot spot, all works fine and I get my Yahoo home page and can access my mail
    Is this a plot against us Texans?
    Must be works every time last Friday to present here on the California coast
  • MyYahoo.com which is my home page and access point to my yahoo mail. No error msg, just won't do anything.
  • what error are you seeing? are you trying to access yahoo.com or mail.yahoo.com or some other variant?
  • They must be down as I too can not update my mail or other Yahoo features.
