longislandcampe's avatar
Sep 09, 2016
Can't Get DirecTV To Work in Trailer....
So my sister has DirecTV but no one else in the family does. We decided to get our parents a DirecTV HD dish so they could watch TV when camping. So far I haven't been able to get it to work. I'm good with tech stuff but I have no experience with satellite TV.
For starters, here is the HD tripod we got. HD Tripod
My sister got the receiver box and the b band convertor straight from DirecTV. Even though this is an amazon link, this is the box we got. I just wanted to show you what model it was. Receiver Box
The first thing I did was hook the dish up to the outside camper cable outlet and then disconnected the jumper camper under the TV and hooked everything up as instructed. I then went from the box to the TV with HDMI and when I plugged the box in I got DirectTV on the screen and it said something about step 1, searching for satellite. After a few minutes I got an error message 775 saying that the box could not connect to dish. I checked all the fittings, unplugged the box for a minute and then plugged it back in but got the same error message.
At this point I unplugged the box and then got a new coax cable and went directly from the dish into the satellite finder box and bypassed the camper wiring completely. My connection went dish to satellite finder to b band box to receiver. Again I got the same message, 775.
I unplugged the receiver, then I took off the satellite finder and went dish to b band box to receiver and I got the same 775 message.
Last but not least, I took off the b band box and went dish directly to receiver and plugged the receiver back in. Again, I got the 775 error.
Am I missing a part or something? For what it's worth, there were times I saw a light come on inside the satellite finder but I have no idea how that happened.
  • Ivylog's avatar
    Ivylog
    Explorer III
    You cannot use the trailer's cable connection. You must run a coax from the dish straight to the receiver.
    That tripod will make it hard to get all three sats for HD. The mast must be plumb/level so the tilt of the dish is correct.
  • First, that tripod has to go. Go to tv4rv.com and check their good tripods for HD. Why do I say this? HD is much more finicky than SD, and you need to insure the mounting mast is as plumb as possible.
    I use a SWM lnb so I don't need any boxes. That requires separate power. You didn't say anything about what direction you aimed the dish.
    I hope your parents aren't all that old and have a lot of patience. Learning to aim one of these things by hand can take effort.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
