- CA_TravelerExplorer III
ScottG wrote:
X2 There are CB antenna for grounded and not grounded (NGP) antennas depening upon vehicle construction.
Don't know what you mean by "regular antenna" but if you're referring to an AM/FM antenna the answer is NO. It is not tuned correctly (can't be) and you will fry the finals in the CB that way.
CB usage seems reather limited these days. - ScottGNomadDon't know what you mean by "regular antenna" but if you're referring to an AM/FM antenna the answer is NO. It is not tuned correctly (can't be) and you will fry the finals in the CB that way.
- ArchHoaglandExplorerMountainAir05 said: "Make sure you tune it using a swr meter."
That is an absolute must do! - MountainAir05Explorer IIJust get a top loaded antenna and you do not have to worry about a separate ground. It gets its ground thru the coax. Make sure you tune it using a swr meter.
- KD4UPLExplorer IIA "wire" like a #10 copper wire for instance, will not work very well to make a good RF ground plane. You would need to use something like a wide copper braid strap. Even then, the antenna really needs a ground plane directly under it to work very well. What RV are we talking about? If you have metal framing: metal studs, metal roof trusses, etc. then you may do okay. If you have a wood framed RV then it won't work well.
Years ago Radio Shack used to cell a CB antenna that was advertised for marine use and didn't need a ground plane. I don't remember the specifics of how it was constructed. That's what I would do, look for an antenna that doesn't require a ground plane.
Technically, your RV does have a ground plane in the frame, engine, and any other metal but it's generally too far removed from where an antenna would go. - agwillExplorerI believe you meant the case of the radio. The coax is already running to the case. Most antennas work best with a ground plane which is usually the other half of a shortened antenna. Good question but try YouTube for suggestions on antennas.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 05, 2025
