Woodtroll's avatar
Woodtroll
Cell Phone Booster and Wifi Amp Antennas on Same Mast?
Hello, friends!
Based on a lot of reading here and elsewhere, I have decided to invest in a cell phone signal booster and a Wifi amplifier. We won't need these often, but we do stay in several places where they would come in handy. Since I won't use them all the time I've decided against a permanent antenna installation, but would rather mount both antennas on the same, temporary mast that I could set up as needed. If I use a cell booster antenna such as the omni-directional Wilson trucker-type or something similar on the top of the pole, then use a flat panel directional antenna below that for the Wifi, I figured I could set up the mast, point the directional Wifi antenna in the direction of the campground Wifi, and be all set.
Do any of you folks who understand the magic of electronics know of any idea why this would not work? If it matters, the cell booster is the Cyfre CA-819, and the Wifi booster is the Alfa AWUS036NHA.
Thanks very much!
Regan
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
