MEXICOWANDERER's avatar
Dec 17, 2015
Charging Smaller Lithium Batteries Gently?
For a long time Nook insisted their ereader be recharged off the USB port of a computer. Mighty inconvenient at times. But I do realize that hammering the little guy with lots of current might be detrimental to its life. Down here I would be well and truly "threaded" if the Nook goes belly up. The last time one did I went without for five months.
So here comes the question...
What kind of power do computer USB ports generate? My earlier post had to do with "N" and "NA" ports on a USB wall wart. For some reason a 50/50 chance I have been connecting the NOOK to the A and my cell phone to the NA ports.
But would it not be wise to limit the charge times to say shut off after 12-hours?
Also with lithium technology does discharge depth limit the number of usable cycles? I have been recharging the NOOK when I gets down to 50 - 70% remaining capacity. Is this a wasted effort? Like no difference if I allowed the battery to discharge to 10 - 20% remaining?
The cellphone stores, an extremely select extremely long way from here want 40 - 50 dollars worth of pesos for a Hwang Ho brand replacement battery for the Samsung, and I am simply out of luck with the NOOK.
Added-on question: The USB charging cables seem to "wear out" after several months. That allows them to simply fall out of the device to be charged USB port. Is there such a thing as a better cable to stop this?
Thanks for your help. With lead/acid batteries I know my stuff. With Lithium I know enough to ask...
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
