Travel_Man's avatar
Travel_Man
Connecting Winegard G2+
Can someone tell me the correct order of connecting things? I have the Winegard G2+, a Direct TV receiver and Sat Input connection on the outside of the RV.
Here is how I "THINK" I should do it.
Winegard inserter box plugged in but not powered on.
Direct TV box unplugged
TV source set to Satellite
1. Connect the cable to the Sat Input on the RV
2. Connect cable to the Dome
3. Push button to power on Winegard Inserter box.
At this point Satellite dome should search for a signal
Once it finds signal plug in Direct TV receiver.
Should now be able to watch TV
Is this the right order of doing things?
  • The satellite cable comes into the rig, where does it go?
    I am thinking it is attached to the antenna booster power supply.
    My rig came with a video switch to separate antenna, cable and satellite from each other. it also makes it possible to watch different TVs from different sources. (only one satellite source)
  • Source is set to satellite. Antenna switch off...hmm, don't think we have ever turned that off but will make sure when I try it again later today.
    Thanks!
  • Make sure the antenna booster power switch is off.
    Do you have a video switch to change from different sources?
  • This setup procedure has worked in the past. But now we cannot get it to find a signal. Connecting the cable directly to the inserter box it begins searching and find a signal right away. I suspect that something is going on with the connection at the RV. And of course that is all inside the walls. LOL
    Thanks for your help everyone!
  • We have a G2+ and your directions seem correct. Once the power inserter is powered, it should provide power to the dome to start the search process.
    The other way to test would be to bypass the Sat connection on the outside and route the cable direct to the dome through a window to see if the RV cabling is somehow bad.
  • What seems wrong with it? I have that manual and it is set up as per the instructions. What do you do different?
  • I have an early Carry out which is somewhat different. Your set up doesn't seem correct.
    here is instruction manual.
    G2 manual
    Make the outside cable connection does not go through any devices.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 12, 2025
