Big_Katuna's avatar
Big_Katuna
Explorer II
Jul 13, 2013
Converting to SWM Diplexers, splitters ok?
Directv came to the house and upgraded me to a new SWM LNB and three new HD-DVR's. I bought an extra SWM LNB, power inserter and 4 wide splitter from the tech for $30 (going rate on Ebay)to convert my RV.
I have been using a Slimline dish with 2 wires going in thru a window and 2 wires going to the outside tv.
My RV is configured like most and I am hoping SWM will clean up the install. The goal is to have a sat box and OTA_TV signal at all three TV's.
I have a park cable input in the water bay that goes to the front A/V shelves (adjacent to the front TV). In the A/V area there is also a OTA-TV antenna cable, and a cable to the rear TV. There is also a cable at the rear TV that goes out to the outside TV. I currently feed the OTA-TV to the rear and outside tv that way.
Now I want to connect the SWM dish to the cable input to get it to the A/V area and install the power inserter and splitter there.
Then I am going to split the antenna to feed the front TV and to a diplexer. One output of the SWM splitter will feed the front sat box and use another to go to the diplexer. I will connect the diplexer output to the cable going to the rear of the RV. I want to split the diplexed feed to the cable going out to the outside tv, then un-diplex both so I have SAT and OTA at all three tv's using separate cable boxes when I want.
Anyone done this? Hints? I see SWM rated diplexers and splitters on Ebay and Solid signal but I am worried I am pushing the attenuation limits. Find out the hard way I guess.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
