rk911's avatar
rk911
Copy/Paste Issue
i'm having an intermittent copy/paste problem. OS is Win7 Pro 64-bit with all critical updates.
I can copy/paste within MS applications such as Word, Excel, Outlook, etc., but when I copy text from a .txt word document it will not paste into RV.net. it's worked in the past but not lately. tried a few suggestions thru a google search including removing and re-starting RDPCLIP.EXE and deleting a Word 12 data file from the registry. neither worked.
suggestions?
  • SCClockDr wrote:
    For more than a year I have been using Ditto. It saves what you place in the clipboard so you can access it later if you wish. Makes forum posting much easier and more reliable if I remember to copy my post text prior to publishing.
    tried that earlier today with no success.
  • 1492 wrote:
    You may want to try placing both applications, browser and word processor, side by side using WIN 7 snap. Highlight the text you want to use in your post. Then, hold down your left-mouse button, and drag into your browser. Make sure you do so within the Forum's "Post a Reply" window. Does this method work?
    nope, sorry. but thanks for the suggestion. never knew about snap.
  • For more than a year I have been using Ditto. It saves what you place in the clipboard so you can access it later if you wish. Makes forum posting much easier and more reliable if I remember to copy my post text prior to publishing.
  • You may want to try placing both applications, browser and word processor, side by side using WIN 7 snap. Highlight the text you want to use in your post. Then, hold down your left-mouse button, and drag into your browser. Make sure you do so within the Forum's "Post a Reply" window. Does this method work?
  • I just moved to a newer computer this week with Win7 and today find I can't copy/paste to the forums here. Probably haven't been able to all week, just today was the first time I tried.
    So I'm following this thread and hope someone posts the answers we both need!
    I just copied and pasted your post and didn't have a problem. Sorry,I don't know what your problem is or how to fix it.
    I have found that sometimes the blue copied symbol lies, so I always right click and select copy, just like with XP.
    Phil
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
