- rvtenExplorerGuess I will be getting a replacement from WFR.
They contacted me. Gave me a six to try that did not work. - 2FliersExplorerMy Cradlepoint has served me well for almost 4 years. Wife and I work full time, and the MBR-1000 could not be more reliable. We're connected with our work computers 8-10 hours per day / 5 days a week, and have not had any issues.
- rvtenExplorerNo I have the WFR GO.
UPDATE A FEW MIN. AGOR
I can conn to WFR with computer. WFR sending conn/
But will not work with ipad/phone.
Sorry to HiJack this. But maybe will help other to decide on what to use. - aluminum03Explorer
rvten wrote:
Just updated my WFR. It was working. Turned it off and now NaDa.
Has power. Boots up I get five GNR lights than gone. Ant light comes on than us gone.
Have GNR lights next to power conn.
VZ air card powered up.
Sent an e mail with my iPhone to WFR. See what results I get.
Something like this happened before. The WFR bricked. They replaced it.
Using iPhone as a Hit Spot right now
Hi RVTen,
WFR wil replace any unit that fails due to an upgrade. Do you have the original WFR? The black cased one? If so, they will upgrade you to the Go with the replacement, which will give you a bit more power and some better power options. Look for an email response today. - docjExplorer
Were you updating it to the 6.6.3 firmware? The company is aware that certain units are unable to take the update because of defective chips n the OEM units on which the WFR routers are based. All routers affected by the update have been replaced at no charge regardless of warranty status.
I'm sure the folks at WFR will be in touch ASAP to diagnose and/or replace your router.
Joel - rvtenExplorerJust updated my WFR. It was working. Turned it off and now NaDa.
. - camper_davidExplorerMy wife works on the Internet as well and we are full timers (relatively new ones). I am using a pep wave balance 30 router, which does pretty much anything that I want, though it is expensive. What I like is that it will take a USB modem as well as wifi as wan and load balances everything. I have a passive external antenna on an extendable flagpole for better reception plugged into the modem. This modem does not have wifi in it, so I am using two wifi access points plugged into the LAN side (one for 2.4, one for 5 ghz connections).
I bought most of my stuff through 3gstore.com, and they were very helpful. I also have the printer and a home server on the network, so it is pretty busy on the two bands. We are with Verizon right now, but I bought a refurbished modem to avoid a new two year contract. This setup is working very well for us so far, and we homeschool and work through it. - joebedfordNomad IIII have a WiFi Ranger with Boost. Works well, but it's picky. Less so with latest firmware ... it's less trouble than trying to hook everything to a MiFi.
Can't speak to Cradlepoint. - Bill_SatelliteExplorer II
I was under the impression that cradlepoint would not connect to MiFi units, in fact that's what they told me when I called them. Are they connecting wirelessly or are your MiFi's tethered? Which MiFi units are you using? Also are you able to use park internet with your cradlepoint?
Yes, the WiFi Ranger, Cradlepoint, Asus, Pepwave (likely others) can connect to the parks WiFi using what is called WiFi as WAN. If you are looking at a router you want to be sure that this is an option. Not all routers will do this including some of the Cradlepoint routers.
All routers should be able to connect to a MiFi device wireless since that's nothing more than a wireless broadcast. As long as you know the passcode you are in. The issue is wanting to connect a MiFi to the router via USB cable so first the MiFi has to have a USB port and the router has to be able to support it.
Cradlepoint only lists one Verizon MiFi that is compatible via USB and that is the Novatel Wireless MiFi 2200. - Bill_SatelliteExplorer III only got "off the train" about 2 weeks ago!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
