theoldwizard1's avatar
theoldwizard1
Explorer II
Mar 20, 2018
DC-DC battery charger - Is the Grail hunt over ?
While "wandering around" the internet, I found a relatively new product. It is a DC-DC battery charger, designed SPECIFICALLY for charging a "house" battery from your vehicle charging system while driving ! In theory THE GRAIL QUEST IS OVER !!
The CTEK D250SA takes current from your vehicle charging system as low as 11.5V and boost it up to the appropriate level for doing a multi-step charge on your house battery ! Additional features:
  • Isolation between vehicle battery and house battery when the ignition is OFF
  • Input from solar array (up to 23V and 300W) and does propper MPPT charging
  • Different charge profile for AGM house batteries
  • Back "trickle charge" vehicle battery if it is low and there is adequate solar power
The downside is, it is limited to 20A, but you are not likely going to be able to push more than 20A through a typical 7 pin trailer connector anyway. (They do make an option that will do 120A but now you are likely going to need ZERO gauge wire !)
EDIT - The older D250S does not have the capability to properly charge AGM batteries, but it does cost less.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Apr 10, 2026
