Keep in mind that you simply cannot move a card from 1 receiver to another. If you want to pursue that route you will need a new card. However, here's some info I posted elsewhere.......
IF THIS FINALLY DOES HAPPENS, as DTV had been promising for about 2 years, domes and 18" round dishes will not stop working. However ALL SD receivers will quit working. The other issue is that dome and 18" antenna users will now receive programming in full HD (with an HD receiver) but what programming will be available is still unknown. You will still only be able to receive programming from the 101 satellite and the majority of programming is currently on 99 and 103. The 101 will still be around for many years to come so if they cut out the SD they can move more programming to 101. What makes the most sense to me, however, is that they would no longer need to duplicate channels on multiple satellites so, at best, less than 1/3 of the DTV programming would be coming from the 101 satellite. So NO NETWORK programming at all and a highly reduced channel list would be available to those to continue to try to use the outdated dome technology.
