- 2010LibertyExplorerWhen we changed over to HD and DTV does not provide a tripod I simply changed ours to work.
I asked the tech for a tube the size needed to fit the big dish and added some of it to the small tube that i had been using. I first drilled a couple holes in the larger tube to allow sheet metal screws to fit. I then drilled them into the inner tube holding it to one side of small tube. I then went to a buddies house and welded them together.
I had looked at Dish tripods and they looked the same except the center tube diameter.
We have used this for over 2 years without issue. I do get a few looks when we have service come out to get us working when something fails. We move seasonally and wind nor hail seems to bother but rain that can be an issue - Big_KatunaExplorer III couldn't agree more. I have time on my hands, a shop, I LOVE going to scrap yards and junk yards. I make my own smokers, temperature controllers, sous vide cookers etc
If you want to pay $150 for something I put together for $40 go right ahead.
I'll spend the extra bucks on diesel or Grey Goose. - nomad297Explorer
Big Katuna wrote:
nomad297 wrote:
LarryJM wrote:
Big Katuna wrote:
I use mine on asphalt often so I can't drive stakes which seems like a pain anyways.
Mine has never fallen over. I just spread the legs out very far.
An Align a site is a $160 piece of un neccesary plastic.
I use Dishpointer on my iphone.
Spoken like a true "UNINFORMED" non Align-a-site owner/user. I won't even attempt to explain the advantages of something like the Align-a-site over things like the iphone apps, but having used both there is "NO COMPARISION". Try using an iphone app to site a dish between two tree branches with leaves on them and see which is easier and more effective to use.
Also, as already mentioned the Sat dish mount does not have to be "plumb" to properly aim the dish using the Align-a-site system.
Larry
Not saying that the Align-a-site doesn't work, but when used with a Slimline dish, if the mast isn't plumb, how do you obtain the correct skew for satellites 99 and 103?
Bruce
I think You have to loosen the adjustment bolts and re level it to the
Level on the Align a sight which is a way bigger pain than leveling the tripod.
The surveyors tripod levels in seconds no wrenches.
I have watched the AAS being used and I think my $5 app that superimposes the sats on my camera screen works just as good for $150 less.
I set up in tree covered state parks routinely.
I agree the TVRV setup is fine. But I'm a cheapskate DIYer.
I went a scrap yard and found a 1/4" thick aluminum plate 4" wide and 12" long.
I drill a 5/8" hole in the middle and bolt it to the hole on the tripod with an upside down 1/2 eye bolt with a wing nut. You could use a bungee thru the eye bolt to a stake or a bucket of dirt but I have never had to the tripod is so stable.
I sat the dish bracket on one end of the plate and outlined the mast hole.
I drilled three holes and bolted the dish mount to the flat bracket with J bolts.
Total cost about $8. I paid $30 for the Pentax tripod on Craigslist. I out a plastic bubble level on the bracket.
I guess it all depends on your situation, but to me, time is money. And if I was to spend the time you spent rounding up the parts and making a setup like you have, I would be out big bucks compared to buying the tripod setup from tv4rv.
Bruce - Big_KatunaExplorer II
Larry
Bruce
Total cost about $8. I paid $30 for the Pentax tripod on Craigslist. I out a plastic bubble level on the bracket. - Carl_n_SusanNomad IIAnother TV4RV user here. While a surveyor's tripod works well also, it does require you to fabricate an adapter plate. For a complete ready to go system, the TV4RV solution is slightly more expensive but makes alignment a snap.
- Fishy_Old_ManExplorerThanks very much to the replies. I do appreciate it.
- lynndiwagonExplorerAnother recommendation for the TV4RV tripod rig. I guess you could get 101 with the dish not plumb and level but you run the risk of not getting the other two, which is the entire purpose of a Slimline 3, as in 3 satellites.
- nomad297Explorer
Larry
Bruce - LarryJMExplorer II
Larry
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
